Cleaner DVD Ripp
    Yeah, I did that too, move slider, exit settings & jump back in without restarting and it shows you what you have set it to.
      Right... but if you know you are 20 off or something you can type 20x. I got near then used arrow keys and watched tens digit change, then I knew I was 10 away. That got me set faster than mousing around (besides I'm pro-keyboard anti-mouse anyways). Cheers.
        This will be fixed ASAP. It turns into a black square if you run the slider back and forth 20-30 times LOL.
          Me too, then you will be able to fly through PE after you get comfortable with it and the keybrd strokes. I even had the author of the Preview window (JeanL) add the Shift + B for the blanking of cells in the Preview window while Tracing. I got tired of poking with the mouse ....
          FYI: The guide will focus on the keybrd strokes.
          BTW/EDIT: I forgot to mention if you are going to use PE, the BOV's (buttons over video) the sliders being discussed, that is covered by PE when first Open a DVD folder ...
          AX
          The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
            Drewster thanks for the tip.
