Originally posted by audrey j
View Post
Transformers 2
Guest
I have tested it with Full Disc, Customize and Main Movie with Transformers 2, works fine. PathPlayer must be in the Always Enable mode.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
nitz
Please see this post:
if you are using an older version of DVDFab. It has worked for many users. Follow the instructions closely.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
It worked for me. I just copied the new Transformers movie on Full Movie mode, not the main movie. All you need to do is make sure the PathPlayer setting is set to "Always enable" in the custom settings on the new version of DVDFab. I just want to thank you techs from the DVDFab group for coming out with a fix to resolve this issue. I think the production companies came out with a new protection code to prevent people from backup their DVD movies. There forever coming up with new protection codes to prevent copying of the DVD movies. I think it's a stupid idea for the companies that make billions upon billions of dollars on DVD movie sales, that they would actually prevent you from copying your own DVD movies you purchased. Anyway, thank you for coming up with a fix. Thanks....c0afanh.Last edited by c0afanh; 10-28-2009, 02:29 AM.
Thanks for the feedback c0afanh. The new verison worked perfectly for me too.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
not working for me... i've done everything listed here, however pathplayer options is NOT an option for me on my dvdfab 6.1.2.5 non-css version.
another issue i have is that it says when it opens the disc and scans it that dvdfab can not open this css protected disc.
any ideas?
and yes, i do have a purchased version...
