DVDFab is not reading DVD's in the source drive. The DVD has no problem being played by PowerDVD DX or by VLC media player. I tried starting to play the DVD and then loading DVDFab, but it still failed to detect the media.
Next I tried copying the DVD folder. That failed with the error
The same error appears even when the DVD is playing.
In a separate window, it appears to be loading and analyzing the DVD, but the progress bar just continues forever without stopping in that window.
I tried copying the folder from the DVD to the desktop and then dropping it into DVDFab and that worked. It just cannot read from the drive.
I tried updating to the latest beta (8.1.0.6qt) with the same result.
Here is a log file showing what happens:
I tried disabling path player, but that did not help. I'm not sure what to try next.
Failed to Open D:\
Please check if it's playable
Code:
2011-07-20 21:22:44 ---- ******************** Log session stop 20-Jul 21:22:44.299 PID 564******************** 2011-07-20 21:21:29 Info Current Drive selected : 1:0:0 - TSSTcorp DVD+-RW TS-H653G DW20 [D] (Ide) 2011-07-20 21:21:29 Info Using Advanced SPTI interface 2011-07-20 21:21:29 Info System default language : English (United States) 2011-07-20 21:21:29 Info User default language : English (United States) 2011-07-20 21:21:29 Info DLL Version : 4.0.20.488 2011-07-20 21:21:29 Info DLL : C:\Program Files\DVDFab 8 Qt\vso_hwe.dll 2011-07-20 21:21:29 Info Version : 8, 1, 0, 6 2011-07-20 21:21:29 Info ExeName : C:\Program Files\DVDFab 8 Qt\DVDFab.exe 2011-07-20 21:21:29 Info OS : Microsoft Windows 7 Professional (Build 7600: Service Pack 1) 2011-07-20 21:21:29 ---- ******************** Log session start 20-Jul 21:21:29.207 PID 564********************
