dvdfab crashing computer getting BSOD
    Toshiba P755
    I have a Toshiba P755, Win7, Core i5, installed DVD Fab QT series, all flavors and consistently receive the BSOD when burning a disk.
    Does DVD Fab not work with Toshiba's? I have read all the postings and it appears everyone with a Toshiba laptop is encountering this problem and it does not appear Fengtao (DVDFab - whomever) is addressing this issue.
    I just need a yes or no answer, does DVD Fab work with the P755, Win7? If no, I would like a refund if yes, please post specific and complete instructions on how to get it to work with the laptop.
    And yes all drivers are current.
    Please response asap, I am on a deadline and need to get a different product if this is not going to work.
    Regards,
      @ SodaWerks
      I suggest you be patient as they try to figure out why this is happening.
      If you are so upset why don't you contact Toshiba about this problem!!!
      CBR929
        No it will not work with our Toshiba. I use DVDFab product on my home computer & other software on my Toshiba Laptop Good luck.
        Last edited by 90312; 03-30-2012, 12:38 AM. Reason: Removed the name of compititor's software
          DVDFab 8172 should had fixed this issue.
          Download:
          resigned
            Also you can try the latest official version of DVDfab 8173,
              I tried the beta and still got a BSOD. It did BSOD a few seconds later than before. However the end result was unfortunately the same. I sent my minidump to Xubin.
              Thanks for working on this one guys.
                @buschman
                Thank you, i am checking now.
                resigned
                  Sorry haven't fixed yet.
                  Now we can reproduce this bug by Toshiba 770, i am checking, need some time because 770 has no 1394 firewire interface...
                  resigned
                    We have send this issue to VSO. Now can avoid this issue by switch to "DVDFab Burning Engine":
                    resigned
                      Does this only work for 8172/3 or will the same approach work for older versions displaying this problem?
                        Work for 8172/3 only.
                        resigned
                          YES! This does work!
                          Thank you Xubin
                            I have a Dell Computer, Windows 7, 64bit and get the BSOD. Currently using 8.1.7.6 and get the BSOD every time right when I eject the original disk from being copied.
                            Do I need to roll back to an earlier version of dvdfab? if so, how do i do that?
                              Xubin, this resolved my issue. Thanks for your help!
                                Thank You Xubin that worked for me using 8.1.7.2 No more hooking up the external writer....
