dvdfab crashing computer getting BSOD
    Originally posted by 1st!_Blood% View Post
    Would you please post the Memory.dump file where it is in %SystemRoot%\Minidump
    And sure that your system have set Kernel memory dump.
    How to check this?
    Please do below steps: run sysdm.cpl -> Advanced -> Settings(Startup and Recovery) -> Kernel memory dump (Write debugging info).
    Thanks,
    Potti
    Hello 1st, Thank you for your assistance. Attached are the Win7 BSOD files created at the time of the error. The Kernel mem dmp (Minidump) and also a sysdata.xml file (since the file upload system doesn't allow xml this size I appended .dmp to the file). I also included the DVDfab internal and vso logs.
    Best regards, ALANBS
      Anybody following up on this after I posted the dumps and logs on 11/11?
        Well, anyway. So I tried the write to disk as destination, and then write to DVD as a seperate operation. This to isolate the read operation from the write operation on the built-in BDRW.
        Using the disk as destination was fine. However, when I did the write to DVD on the BDRW the laptop BSOD again. This was after the write operation was completed/finalized.
        It was like DVDfab was doing closing/cleanup after being done with the write and then it happend.
        Attached are mini and standard memory dumps, and the DVDfab logs.
        At this point I'm feeling that DVDfab is not doing proper close/release instructions to the BD drive and it is causing the driver to fault and go BSOD.
        I wish the engineers good luck in finding the cure. Until then i'll be using my old pc with only a DVD drive to do my backups on.
          The most recent internal log indicates that the source disc was never opened, so it has nothing to do with the burn part of the process.
            IRQL
            I have the same issue and originally thought it was the laptop that I had purchased and returned it. After reading more posts on the net, I realize now that there is an issue.I have the same issue as everyone else out there, when it finishes the copy and it's ready to start the burn process, I get the BSOD every time.
            Some sites said that there is an issue with vso and to try imgburn, but I use nero and it does it everyone; I;m afraid. Interesting enough if you let the copy done to the hard disk and then do a write, it only fails under vso burning engine, but not under imgburn or nero.
            I matched the settings from my old computer to the new laptop and they are identical, so frustrated with this.
            I love this product and wish that it would do it like it used to and run ask for the DVD to be loaded and then write it, but I have to work around it with a hard disk copy then a write.
            Could it be a compatibility issue with the dvd drive? Most of the people that have posted on sites own toshibas, which is my machine as well and if the manufacturer uses the same type of dvd drives/drivers maybe that is it.
            Any new insight will be helpful.
            Thanks
            Ray
              Are you refering to the logs attached to #93? Where the source was the HDD copy created in a prior DVDcopy from the DVD to the HDD, and the write operation to the DVD completed successfully then BSOD occured?
                @rl0822 It is happening to new laptops that have BD drives. The brand doesn't seem to matter or specifics have not been isolated.
                I don't think this is getting reported properly as most people first think it is something wrong with their new laptop, as the same DVDfab program version is working fine on their other machine(s) with a DVD drive.
                Thanks to your posting and others, I will try the ImgBurn software instead of VSO. I've never had issues with using VSO before.
                I hate having to do work-arounds.
                Lets keep our fingers crossed that the engineers are getting a handle on what is wrong.
                  Hi alanbs
                  Please try the latest version found here
                  Have you also tried disabling Path Player?
                  You should not have to do this but give it a try
                  Open Fab Click the Green top right > Protection > Path Player click Disable Path Player click OK restart Fab and try again, just remember to set it back to Always Enabled.
                  If you want to use ImgBurn you will find instructions in the link in my signature on setting it up.
                  Remember to set up the AWS and burn at 1/2 the rated speed of your disc.
                  CBR929
                    just bought toshiba satellite 755 windows 7 home premium with an i7. Just downloaded the 8.1.3.3, and as soon as 100% of dvd is temporarily copied the dvd burner ejects it and out comes the BSoD, i tried running earlierversions off an external harddrive which now are causing the same BSoD. What is going on?!!
                      IRQL
                      I tried to disable Pathplayer and I got BSOD, so that did not seem to fix the issue. Don't understand why this is happening. My old HP laptop did not have any issues whatsoever. I have another HP laptop and does not fail at all. My desktop is an HP too, so seems like Toshiba drives are the issue, if you ask me.
                      I do not have a bluray burner with the Toshiba laptop.
                      I have a gateway desktop and before this Toshiba laptop had a gateway i3 laptop and never encountered an issue.
                      The drive is Matshita and wonder if these other folks here that have Toshiba products also have the same manufacturer
                      I was thinking of buying a new burner and installing it to see if that remedies the issue, but not sure of that yet
                        I thought it might be a Toshiba drive issue (mine is a Bluray) but my husband's new HP also BSODs at the same point. My older HP laptop works fine. FWIW, they all have Windows 7.
                          I disabled the path player as well but no change, still got BSoD. I also had this program working without fault on a dell laptop, hp laptop and a compaq pc. is it possible to switch out my broken hp laptop's dvd burner withmy new toshiba's?
                            A dmp ZIP would be helpful
                            Please look in .../windows/mini dump
                            Attach the NEWEST minidmp file you see there.
                            If it's like the one from early in this thread it is a very ugly driver error. X'D1'.
                            The system attempted to access pageable memory using a kernel process IRQL that was too high. The most typical cause is a bad device driver (one that uses improper addresses)
                              Attached is the latest dmp file I think I attache it properly
                                IRQL
                                After trying so many things, I decided to return the Toshiba Protege. I purchased a HP Pavilion laptop and as I suspected no issues at all during the burn phase of the process. This makes me more convinced that it has to be something with either the driver and manufacturer related to the laptop. I bought two laptops and each one had BSOD at the same phase in the process of starting to request a blank dvd to burn.
                                Good luck to all of you still having issues, I was fortunate that I had 30 days on my laptop and returned it.
