exact same problem with 9.1.0.6 - won't work on XP
DVDFab 9 problems with Windows XP
I'm not having any issues on my XP computers at all. I had an issue back in version 8qt and it turned out to be an issue with my Nvidia drivers. I uninstalled DvdFab and the Nvidia drivers,ran Ccleaner, installed the newest drivers and reinstalled DvdFab and it's been fine ever since.Last edited by Frankster91; 11-15-2013, 03:45 PM.
Originally posted by Gummigutta View PostWhat nvidia card (model) do you have installed?
I mean no disrespect to the Dev's, but I think this has fall'n on deaf ears, this has been a problem since 9.0.6.5, we are now at 9.1.0.6 and the problem is still there. Every one says up grade your Windows version, I'm a little disappointed I would have to do this as 9.0.6.3 works so well, it couldn't be that with all these changes that have been made, that someone made a mistake in programming or are all of our XP versions the culprit, I don't think so!
Regards,
Originally posted by Frankster91 View PostI'm not having any issues on my XP computers at all. I had an issue back in version 8qt and it turned out to be an issue with my Nvidia drivers. I uninstalled DvdFab and the Nvidia drivers,ran Ccleaner, installed the newest drivers and reinstalled DvdFab and it's been fine ever since.
Do version(s) later than 9.0.6.3 work OK on any of your XP computers? Which one(s)?
Do they have .NET installed? If so what version(s)?
Do they have MS Silverlight installed?
Any other special software installed that might be needed?
Originally posted by Eddie13 View PostAs shown in my DirectX Display graphic above, it's NVIDIA GeForce 6200. I just updated to the latest recommended driver but that didn't help.As shown in my DirectX Display graphic above, it's NVIDIA GeForce 6200. I just updated to the latest recommended driver but that didn't help.
Originally posted by Eddie13 View PostThanks very much for that info. I might try your procedure, although version 9.0.6.3 and former work fine on my XP computer. Only later versions have a problem...
I have .Net installed version 2 through latest release.
Silverlight is installed.
Not sure if this will help you but this is what I did to correct my issue.
(Make sure you have your Reg key) Also check Windows Task Manager to make sure there is nothing Fab related still running, this will prevent it from uninstalling correctly. You may have to force kill it. I had more than 3 instances of it that kept coming back up and had to keep killing it until it stopped.
I uninstalled DvdFab. Rebooted.
I uninstalled my Nvidia drivers. Rebooted.
I uninstalled the Nvidia System tool.(If you have it but its not needed) Rebooted.
I defraged the hard drive.
Installed Newer Nvidia Drivers. Rebooted.
Installed a newer version of the Nvidia System Tool.(not needed but thats what I had. Rebooted.
I ran a search in the registry and removed any and everything related to DvdFab.Rebooted
I ran CCleaner and removed anything that it found related to DvdFab and other needless files. Make sure you have it set to clean the Prefetch as well or do it manually from Windows Explorer. Went into Windows Explorer and removed anything DvdFab related. Rebooted.
Redownloaded DvdFab and verified the MD5.
Installed DvdFab and re-registered it.Last edited by Frankster91; 11-15-2013, 04:40 PM.
Originally posted by Eddie13 View PostThanks, but before I can proceed need to know...
Do you have a version later than 9.0.6.3 installed on a XP computer and working OK?
If so, which version?
I have been running FAB since ver 3.0 and I am running XP and never have had a problem so perhaps it's on your end and not FAB's which is causing the problemPaid Not To Work
US Navy Retired ( 20 Years )
Proudly Served On
USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
6 trips to the Gulf Of Tonkin
Originally posted by Jimbo View PostI have been running FAB since ver 3.0 and I am running XP and never have had a problem so perhaps it's on your end and not FAB's which is causing the problem
Originally posted by Eddie13 View PostYes, that seems to be the case, now identifying the culprit is the next step. Do you have Silverlight and the latest .NET installed on your XP computer? Do you have Nvidia drivers? What antivirus are you using?
