internet problems
    Purchase Problem internet problems
    I don't understand, but i can not connect to internet when starting dvd fab 9
    I definitely have no internet issues, other than trying to start dvd fab 9... is there something i can try, so I can get connected
    when i start it, it says dvd copy expired, but i try to activate it, and says can not connect to internet.. expiry is 2-2-2016
    I am very confused and need help.. not sure what is preventing dvdfab from accessing internet.. sorry i am not an expert in this area....don't understand this configure proxy thing?
    I do not have the direct connection to internet even listed?.... only option listed is to connect through a proxy?? what is going on
    thanks
    Make sure the Manual Proxy Configuration box is NOT checked, it uses direct connection to the internet by default now. Your antivirus/security software may be blocking DVDFab, try turning it off briefly or if it has the option to ignore DVDFab.exe or anything related to Fab, set it so that it will. Most software for web security keeps a log file of blocked connections, see if you can find it listed.
    It is remotely possible that your internet provider has blocked Fab connections, see if you can reach the Fab website at www.dvdfab.cn.
      I'm also having this problem. I have just upgraded to Windows 10, so I thought I'd check DVDFab still worked but I can't get it to connect to the Internet, I've even unticked the manual proxy configuration box but still can't connect.
      My DVDFab is version 9.2.0.5
        No internet connection
        same for me,
        and it's not a firewall or another software problem
        problem with the last beta update
        will
          i disabled the antivirus and manual proxy is not enabled, but still can not connect to internet, only dvdfab 9 has this problem,,
          I just download 9.2.10 onto my newer computer and same issue, i also disabled the antivirus on this new pc Win7 and no luck connecting
          very frustrating..
            so it's not customer soft or harware problem, probably dvdfab server problem
            w
              I can not connect either, Windows 8 and 10. No antivirus or firewall. Something wrong somewhere else.
                check your internet protocol, where it says( obtain an IP address automatically)
                (obtain DNS automatically )
                  Now,I have the same problem. JPN.
                  DVDFab for Mac and Win, both.
                  DVDFab9 doesn't start.
                  I can reach www.dvdfab.cn, I can login forum.dvdfab.cn .
                  I think something wrong, somewhere as someone said before.
                  Please check it. Thank you very much.
                    the problem should be fixed - http://forum.dvdfab.cn/showthread.php?t=27801
                      The problem is fixed but it will take varying amounts of time for it to propagate through the internet to all locations.
                        DNS problem?
                          It has been just 2hours? still cannot connect. JPN.
                          I have tried "ipconfig /flushdns".
                          OK. I'll wait for good news leisurely.
                            If it is a DNS problem, then it could take up to 24hrs to propagate.
                              It's been like 8-10 hrs. JPN.
                              more 16-14hrs to go
                              Have nothing I can do, here.
                              Feel like just, "All things come to those who wait."
