Originally posted by ernielee
View Post
Problem with GTX260 and enabling CUDA decode/encode
Originally posted by EVT View PostFor blu-ray copy it depends on the size and I'm having trouble recalling an exact number but I've been doing a few MKV's lately with the blu-ray ripper module and I seem to get about 35 fps. With blu-ray copy I would say that it usually takes between 75 and 100 minutes to compress the movie only to 8968 MB.
with setting cuda encode / decode software , fast/normal
avg speed are 6.25MB/s 70min to compress.
your time of 75,100 minutes are good and fast.
35 fps are good too.Windows 7 64bit ultimate
CPU: i7 4770K @4.5 vcore@1.28v temps 27c/67c
RAM: 16GB DDR3 @2133
GPU: nVIDIA GeForce GTX 770 2GB
SSD: 2 X 60GB OCZ vertex 3 RAID 0 (boot drive)
HHD: 1 TB WD BLK (storage and back up)
PSU: 760W ,Fans 1x200mm and 2x120mm
Originally posted by ernielee View Postjust backup underworld a 133 minutes movie only BD25
Do you find that you're able with your profile that you successfully can compress VC1 movies since your using CUDA for both encoding and decoding? Perhaps I should consider CoreAVC, at least that way I can get a boost for most movies since greater than 2/3 of my movie collection utilizes AVC.
Originally posted by EVT View PostTo be honest with you, the speed of DVDFab is in my opinion it's best quality. However, having read that a few on here are able to utilize the Cuda Encoder and Decoder successfully I figured I would do my best to maximize the program's capabilities. While you're times seem similar, you must bear in mind that you're using the slow setting while I'm using the fast setting.
BTW underworld setting was FAST/normal.
if I use SLOW/high quality it is about 1MB/s slower to compress.Windows 7 64bit ultimate
Originally posted by EVT View PostSo in your opinion, has Core Avc made a positive difference?
faster for my set up CoreAVC is running about avg 1MB/s slower
but with my setting I have been able to backup 100% of my BD.
Very happy with dvdfab and both of my vidoe cards, GTX275 and GTS250.
Quality on all my backups are great watching on a 60" LG w/5.1 surronnd sound.Windows 7 64bit ultimate
Originally posted by ernielee View Postwell if you want speed w v8.0.0.5 cuda decode,cuda encode is way
in the past coreavc was about .75 to 1MB/s faster with v7.x.x.x
It is nice to have coreavc in my pc as an option.
If you are able to get over 5MB/s when compression in any setting
to that is great.My old pc compression main movie only BD25 was
1.2 to 1.80MB/s 5+ hours.Windows 7 64bit ultimate
Originally posted by ernielee View Postin the past coreavc was about .75 to 1MB/s faster with v7.x.x.x
I don't notice a big difference in speed from COREAVC and CUDA. What I notice is the CUDA processed movie is better quailty, less intermitent glitches and pixelations. Speed both COREAVC and CUDA run between 5 and 7 mb/s.
On a side note: Process speed will increase substantialy if you have/use two harddrives. Read from one, and write to another.
but if you can't get CUDA working, COREAVC is only $12, give it a try.
StuAMD Phenom II X2 550 Callisto unlocked to 4 core Denab @ 3.8mhz, MSI 785GM-E65 M/B, 4 Gig Geil DDR3-1333, EVGA GTX-260 192 Core, Corsair 700 W power, LG-BHO8LS20, LG-GH22LS50, IHOS104 DRIVES, 750 WDC Caviar Green, Hitachi 500, 2 TB WDC Caviar Green, SATA HD Drives, ASUS Xonar Essence SXT Sound, 2 Samsung SYNC 2333'S, Windows Vista 32 Buisness Edition.
